Wood Stove Water Heater
Discussion in 'Off Grid Living' started by BenP, Dec 30, 2018.
  1. Merkun
    Merkun furious dreamer
    Ben, please consider that if you happen to have water in that apparatus over about 130 degrees. and that hose blows, there's a pretty good chance of scalding. If, somehow, it goes over 212 (or the local boiling point) well, you get the idea.
    Tully Mars, Gator 45/70 and techsar like this.
  2. Cruisin Sloth
    Mine has 3 over temp valves , expansion tank on a well. Been fine for 60 years .
    On temp out line tee in a 3/4 pipe over temp valve , your good to go. .
    Sloth
  3. BenP
    BenP Monkey+++
    The water heater tank usually runs 105-110F, I have occasionally seen it jump up to 120F when it was really cold outside and I had the stove blazing. I am going to put an expansion tank on the entire system to absorb the pressure. The rubber hose I mentioned isolates the vibrations from the circulation pump, I noticed it leaking around the hose clamp when the pressure rises and decided just to leave it until I get the expansion tank. The pressure relief valve and the circulation pump are in the utility room so if anything 'blows' the odds of it hurting anyone are slim.
  4. arleigh
    I was contemplating something using a bimetal spring as used on the exhaust system of a automobile engine exhaust system.
    The idea being that the stoves exhaust used for making the heat has a Y or T or both diverted to the water tank so that the heat can be diverted using the bimetal spring on the pipe damper to regulate the temperature.
    oldman11 and Gator 45/70 like this.
  5. We hooked up a water heater next to our wood stove, after removing the insulation and checking the safety valve. It stores 40 gallons of water and lets it get up to room temperature before entering our tiny water heater. I'd like to find a couple of more free water heaters to hook up in a series, but I'd rather do that in the winter when I am not so busy.
    oldman11 likes this.
  6. BTPost
    Why not use a Thermal-Syphon System on your Wood fired Wood-Stove, and have Hot Water, all the time?
  7. BenP
    BenP Monkey+++
    Just set it on top of the stove. :)
  8. My husband and I have talked about it, but we have dozens of other projects that take priority. For example, right now I should be outside working on the wood shed...
  9. BenP
    BenP Monkey+++
    I need a thermostat in the waterline similar to a car thermostat that only opens when the water is hot, any ideas?
    If the stove is cool it thermo siphons all the hot water out of the tank and cools it off.
  10. oil pan 4
    Put a flapper valve so that gravity holds it closed, might be enough to stop thermo siphoning.
    BenP, Gator 45/70 and SB21 like this.
  11. Wildbilly
    On a smaller (and cheaper) scale just sit a couple of 5 gal. metal Jerry cans full of water next to the stove. Make sure that they are touching the stove and that the caps are removed. When the water gets hot, remove them with a pair of leather gloves and enjoy. No fuss! No skills needed! No expense! No danger of explosion!
    BenP, Gator 45/70 and Tempstar like this.
  12. Cruisin Sloth
    Three above ^^^^^^^^^^^^^^ NOPE , DO NOT DO THAT ,
    Its called a mixing valves..
    Never restrict the flow or movement , have a squeeze tank and many over temp / pressure relief valves (like hot water heaters have) on all hot top and out spots . My out hot from the stove is the one I replace every year cuz it can turn into old Geyser , on those cold nights and we do dishes , washing ,, OR Have sex and a shower ( Ya in MY DREAMS ) !!!
    Sloth
    BenP, ghrit, SB21 and 1 other person like this.
  13. BenP
    BenP Monkey+++
    It works well 99% of the time but every once in a while I will wake up to a cold stove and cold water.
  14. BenP
    BenP Monkey+++
    I've got two little kids in school and my wife and I work in town....I think I would have an insurrection on my hands. :)
  15. Cruisin Sloth
    Or someone gets burnt..
    Gator 45/70 and BenP like this.
  16. arleigh
    It might be worth the experiment to find a marble top someone has cast off and create a heat reservoir.
    There are some stoves the actually are encased in stone for this reason.
    However, if the water tank had this encasement with added shielding around it, the water temperatures might last a bit longer through the night.
    Thermal -syphoning has it's advantages and in practical terms if you are running the stove longer than the time it take to use the water at the temperature you are satisfied with, then having a significantly larger secondary resevoir is to your advantage .
    If the secondary is the receiver preheating the water before the primary reservoir the primary can heat pre heated water faster .
    It makes good sense to have safety valves in the system no matter how simply you design it
    Handling open containers of hot water is no fun if you spill it on your self. been there done that.
    Plumbing is always the better way.
  17. Wildbilly
    This is mostly a SHTF set-up, might even be good after an ice-storm. This would make just enough hot-water to clean the high-spots (hair, face, pits, privates, and feet). The military used to teach soldiers how to bathe in the field with just a helmet full of water.
  18. Wildbilly
    The woodstove in my barn is surrounded on three sides and underneath by hollow concrete blocks filled with sand. The woodstove heats the barn and the heat-sink, which continues to radiate heat long after the fire is out for the night.
  19. William Warren
    William Warren Monkey+++
    If any monkeys are around Yancey county, North Carolina, and you're looking to heat water with wood, PM me: I just removed a wood-fired hot-water boiler that was used as backup for my oil-fired hot-water furnace. It's intended to heat water that circulates through baseboard radiators, but you could also use it to either feed a heat exchanger for bathing water, or for the water in a hot tub.
    William Warren
    techsar, Gator 45/70 and SB21 like this.
  20. SB21
    How big is this unit . I may be interested in this . If you have some pics might be helpful as well . You can PM me as well . I'm in the Lincoln county area . What would it take to load and unload this unit . Approximate weight ???
    techsar and Gator 45/70 like this.
  1. Gator 45/70
  2. 3M-TA3
  3. TnAndy
  4. Motomom34
  5. VisuTrac
  6. Kavode
  7. Hillbilly549
  8. BenP
  9. Retread
  10. Asia-Off-Grid
  11. Asia-Off-Grid
  12. Asia-Off-Grid
  13. Asia-Off-Grid
  14. Asia-Off-Grid
  15. Asia-Off-Grid
  16. duane
  17. oil pan 4
  18. Thunder5Ranch
  19. Mountain mama
  20. GOG
