Survival Cache
Discussion in 'General Survival and Preparedness' started by E.L., Dec 26, 2006.
  1. CATO
    CATO Monkey+++
  2. Jay Tx
    Jay Tx Monkey+
    Another tip on using the PVC pipe and burying in a posthole fashion.....The eyebolt is an excellent idea. To go a step further in making retrieval easier, sleeve the capsul being buried with a larger diameter pipe, open on the bottom, screw cap on top. It could even be a second capsule, sealed on the bottom to further protect your cache, with a screw cap on top. Doing this would have the huge benefit of allowing the retriever to unscrew a cap and slide the capsule out of the sleeve, as opposed to digging the entire length of the capsule out of the ground.
    A 6-10" diameter PVC cap will have +/- a 1/4" lip around the pipe. This, after the ground settles around it, will not allow the capsule to freely slip up out of the dirt or gravel, no matter how well it is planned out. When you need it most, you'll spend way more time digging it out than you planned. With the sleeve, once you access the end of the outer capsule, you simply unscrew the cap and lift out your bounty.
    NotSoSneaky, Smitty and BTPost like this.
  3. NotSoSneaky
    NotSoSneaky former supporter
    One word of caution when caching; Never bring a smartphone along with you when scouting possible cache sites or placing supplies on a site. Even if the phone is turned off. (Anyone notice you can't remove the battery on the newer phones anymore ?)
    Use a standalone GPS if you need to be hi-tech or just use a topo map and triangulation if you can't remember things.
  4. oldawg
    I think fienstien must own stock in a pvc pipe and fittings factory.
    KAS likes this.
  5. RightHand
    Time for a Bump - great thread
    NotSoSneaky likes this.
