Your off grid system design
Discussion in 'Off Grid Living' started by Dmitrko, Apr 16, 2024.
  1. Dmitrko
    Dmitrko Monkey
    I know were lucky enough to have a people trying out all sorts of system designs, So I made a thread were you can tell people about your design and how well it works in real life.
    https://100up.com.au/off-grid-solar-ballarat/
    I'd really like to hear from anybody whos made a wind turbine work in real life
    duane and Dunerunner like this.
  2. Out in the woods
    We have 4400 watts of photovoltaic panels, with a 48vdc 600ah battery bank.
    Grid power [when it is available] comes into our system via an 'Aux input' breaker.
    duane, Seawolf1090 and Dunerunner like this.
  3. Dunerunner
    I don't have a system, but I have a plan... Totally Grid Independent
    10 KW Generac propane genset
    10KW Solar array with 10KW battery backup, thus the genset.
    20 acre isolated wooded property with a live stream, creek or spring
    Existing 20GPM well and 5000 gallon storage tank
    Existing septic system or peculation test and mantle approved for said system
    duane likes this.
  4. arleigh
    Years ago, I had a 600-watt mill but I didn't get enough wind to make it worth while.
    I had bought several used solar panels roughly 1000 watts worth. I used 6-v volt deep cycle golf cart batteries and an old automotive voltage regulator because I was always evolving the system, and I could adjust it as needed.
    After i sold my property things changed and i bought several 100 watt Harbor Freight solar panels and they seem to be working just fine however I had gotten some 12 volt boat boat lithium-ion batteries and they were seriously disappointing, fortunately the dealer took them back and traded me for some glass matt batteries which are now giving me far better service.
    The problem with the lithium batteries is that if the voltage drops too low they drop out completely or if the voltage is a bit high they completely drop out. I had to tie in a lead acid battery with them to prevent this fall out. And they didnt actually have that much service time for the money. They've got a ways to go before I invest again.
    The weight of the lithium batteries is impressive being about the same size as a truck battery and half the weight, but I think that's the problem. It takes a much bulkier set of cells in that battery for the depth if storage lead acid batteries are capable of.
    I've been through a few inverters; the best is a pure sine wave especially for fine electronics. Always get an inverter bigger than you anticipate,
    I built my system starting with used equipment and learning on my own from there.
    I put my solar panels and battery bank in an enclosed trailer, that way it goews with me when I move and is not part of the house or property I happen to live.
    If I had property again, I might be persuaded to build a car port and put the solar panels on it.
    Dunerunner likes this.
  5. Wildbilly
    I have a small 12 volt "starter" solar set-up, and in the next few years I plan to increase the number of panels and get a LiFePo4 battery or two. I already have two generators (both gas) and would like to get a PTO generator to hang on my diesel tractor, thus giving me a mobile diesel generator. I'm still on the fence concerning a wind turbine, sometimes the wind doesn't blow but sometimes it does. I don't REALLY need the PTO generator or the wind turbine right now...maybe I'll never NEED them, but better to have something and not need it than to need something and not have it!
    CraftyMofo and Dunerunner like this.
  6. Tempstar
    Tempstar Monkey+++
    Two 325 Kyocera panels, Renogy 60 amp MPPT, 4 100 ah LiFePo4. Not off grid because I like my air conditioning but not worried about power outages either. I have a sub-panel with the essentials that I can feed from solar, generator, or grid. Generator is either my 6KW ex-light plant diesel or my 12 KW 26hp one cylinder Chinese diesel with an ST head.
  7. OzVegus
    OzVegus Monkey
    Same here basically, 500W of panels and 500Ah of trojen batteries. I have grid connect solar on the main roof, far too hot here in summer to go without aircon and I don't want to pay for it. The only people I know who live a "Normal" lifestyle offgrid are wealthy because a system of that scale costs 40~50 grand + replacement every decade and two.
    Tempstar and duane like this.
  8. Scaudy
    Scaudy Monkey
    I am off grid and run a normal house year round aprox 40 acres in Norther AZ.
    5,280 kwh panels
    8,800 watt magnum energy inverter 240 volt split phase
    100 AMP chager
    300 AH lifepo4 server rack 48V battery bank
    7,000 watt propane inerter generater backup (never really need)
    Run regular fdidge, small upright freezer and everything else in the house as normal.
    During summer run inverter style aircon to stay nice and cool. Will upgrade to mini split this year. Range, oven, hot water and heat are all propane. Have a 500 gallon propane tank.
    Also have a small office/cabin on the property that has its own solar setup.
    1500 kwh panels
    3000 watt growatt all in one inverter chager
    380 lead carbon AGM 48 volt battery bank.
    Cabin is really only used during the day and runs a 12k minisplit during the summer with no issues. Heat is vent free propane heater and have a small office style fridg.
    Costs of solar systems have come way down the past few years and you can get decent cheaper equip that can run an entire house for not bad prices (diy). The companies that come around and sell in the cities are very expensive. EG4 makes some decent stuff that does not break the bank.
    Seawolf1090 and Tempstar like this.
  9. Cruisin Sloth
    @Scaudy
    Nice system .
    Im grid tied , but can also be off grid. I don't get a hydro bill (make more than I need).
    % different setups on the ranch and three back woods in the mountains if the weather makes us land and let it blow over.
    Sloth
