planter box
Discussion in 'General Discussion' started by Big Ron, Apr 5, 2019.
  1. Big Ron
    Big Ron Monkey+++
    I was thinking about how effective a ferrocement planter box filled with sand almost to the top, flowers on a thin layer of dirt on top. I wonder what would be a minimum width of the box to be effective as a bullet stopper. I was thinking a foot wide. Of course, more would be better.
    chelloveck and Gator 45/70 like this.
  2. duane
    Brits during WW2 made plastic protective plate, not allowed to call it armor as it had no steel, out of plywood, tar, and stone. If it changes the point impact and penetration to a wider push type, a few inches can be quite effective and were used on merchant ships to counteract aircraft machine guns. Wall designs etc, show that a loose stone filling is self healing against anything but explosive projectiles. The Brits found that the tar both held the stone in place and spread the force out. Planters provide a vehicle barrier, concealment, and cover as well as raising some food. If nothing else they will worry the he** out of anyone attacking as they won't know what else they might have hidden in or behind the planter, a couple gallons of fuel and a command detonated explosive, pipe bombs, a nice deep punji pit with a couple inches of grass, a spider hole that someone can pop out of after you pass the planter and jump up on the porch. Who knows what evil minds might come up with.
  3. john316
    john316 Monkey+++
    Survival Monkey Forums
    Forums > survivalmonkey.com > Survival Articles >
    Short Range Media Penetration by 50 BMG AP Rounds
    50BMG penetration Table From "The Ulimate Sniper" by Maj. John L. Plaster, USAR (Ret). page 222
    page 222
    Short-Range Media
    Penetration by .50 Cal. AP rounds
    Medium
    /Penetration @ 100 yrds
    _____________________________________________________________
    CONCRETE (solid)
    9 inches
    TIMBER (logs)
    96 inches
    STEEL (nonarmored)
    1.8 inches
    ALUMINUM
    3.5 inches
    RUBBLE (asphalt, soil, cement)
    20 inches
    TAMPED SNOW
    (19.9-24.9 lbs/cu ft)
    77 inches
    DRY SOIL
    28 inches
    WET SOIL
    42 inches
    DRY SAND
    24 inches
    WET SAND
    36 inches
    DRY CLAY
    42 inches
    WET CLAY
    64 inches
  4. john316
    john316 Monkey+++
    15 January 2013
    Barriers
    This post has been in draft form for a long time. It really doesn't have much to do with firearms, and more to do with the things to think about when confronted by a barrier.
    An ethical hunter will not take an obstructed shot on game. The rules of good sportsmanship prohibit taking risky shots that might wound and animal.
    A Soldier or even Law Enforcement Officer may need to engage another human being who is using cover or concealment. Let us define each.
    Cover is something that stops the bullets aimed your way. They might be able to see you (through bulletproof glass or a big block of ice), but they cannot hit you with direct fire.
    Concealment simply hides you from direct observation by your opponent. The enemy can't see you, but if they have enough bullets to shoot through the tin shack or apartment door you will learn the difference between cover and concealment the hard way.
    The definitions are fairly simple, but what could be "cover" for a 9x19 could only be "concealment" to a 357 Sig. In fact this little bit of wisdom is why the Chicago Subway Police are issued firearms in 357 Sig, it can launch a bullet fast enough to penetrate a subway seat with enough terminal velocity remaining to do significant damage to someone behind the seat.
    The last few posts in the Firearms Lethality series have dealt with bullet construction and velocity. Barrier penetration is something that has been touched on with Armor Piercing rifle ammunition and KTW pistol rounds. The barriers designed to be defeated were made of steel. But barriers can be anything, from sheetrock to tempered "bulletproof" glass. The guys at the "Box O' Truth" showed that bulletproof glass really is bulletproof, for a while anyways http://www.theboxotruth.com/docs/bot48.htm.
    The truth is that in order to defeat "cover" or a "barrier" all you need is time and ammunition. I don't want to think about how many 22LR cartridges you would need to defeat NIJ level 3 rifle bulletproof glass. But you would need significantly less 50 BMG to get the same effect. Even standard ball 50 BMG would be fine, but specialty rounds are available just for punching through armor steel or bulletproof glass.
    But, bullet design is nothing without some terminal velocity bringing kinetic energy into the act of turning cover into concealment. Toss a rock at a bulletproof glass viewport and you might not even make enough damage to obscure vision, but hit it with a precision 12 gauge slug a couple times and things get interesting to anyone behind the glass. Conversely, if you don't want to go the "big and slow" route, you can always go with the "screaming fast" method. These two schools of thought are not mutually exclusive, and so you can get some really screaming tough bullets. In a low mass, high velocity cartridge like the 5.56x45, making the projectile "tougher" is the easy answer. If you want to compare two bullets against each other, test them against some barrier and find the "V50" numbers (lower is better). V50 describes the velocity where 50% of the bullets defeat the armor in question. http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA567525&Location=U2&doc=GetTRDoc.pdf One should note that using standard M855 or M855A1 bullets in a higher velocity round like the 22-250 or 223 WSM would increase the range at which the bullet would remain "armor piercing." What exactly that extra velocity would do at closer ranges is beyond my ability to predict, but assuming the bullet can behave as designed, ballistic performance against barriers should be improved.
    Now, there are different types of barriers. Bulletproof glass (and most non-homogenous armor in general) uses alternating layers of hard and soft to redirect, absorb, and disperse the kinetic energy and momentum of the projectile. Other types of barriers, such as sandbags or snow (do not underestimate the ability of an unpacked snowbank to stop a bullet) simply use a lot of mass to bleed energy and momentum away from the projectile. Composite materials (carbon fiber reinforced ceramic, resin impregnated aramid fibers, fiberglass reinforced concreate) use a bit of both properties (mass, and multiple materials) in order to spread out the impact to an area larger than the diameter of the projectile.
    The hole in a sandbag will be the same size hole as the bullet. The hole (or impact crater) on bulletproof glass will be orders of magnitude larger than the size of the bullet. Some materials (like homogenous steel) behave more like sandbags than like bulletproof glass.
    In the race between small arms and armor, armor has won. That is why explosively formed projectiles and warheads have been developed, for everything from Rocket Propelled Grenades to anti tank missiles. Because in the end, if your small arms fires simply aren't working, several pounds of explosives usually help out quite a bit.
    Explosives are a lot like machine guns, if you aren't effective, you need to use more.... And if you always choose the biggest, fastest, toughest thing you have, all that remains is to ensure you have ENOUGH of it to defeat the barrier you want to defeat.
    Posted by AM at 18:37
    Labels: barriers, concealment, cover, firearms, lethality
    8 comments:
    StukaPilot
    said...
    I live in deep Mexifornia. Other day I was in the local gun shop and asked about getting some .308 armor-piercing rounds for my M1a. No joy, was told it's not legal in this state. Did buy some 150-gram "standard military ball" .308. Now I wonder, in case of a 3 AM visit by State Security, what kind of impression - if any - would this loading make on ceramic armor at close-range?
    January 16, 2013 at 1:12 AM
    California Midwesterner said...
    Stuka--
    The only 7.62x51 NATO AP rounds are indeed legally prohibited.
    However, M2 AP bullets from .30 ball (i.e. .30-06) are still legal, even here in the People's Republic of Kaliforniastan, to the best of my knowledge. They can be loaded in .308, to similar velocities as their original spec.
    That said, good luck finding any in the current panic-buying climate.
    As to your second point, Level III NIJ armor (as in SAPI--but not ESAPI--plates) is rated to stop 7.62 NATO/.308 Win Ball at 2780fps, though I don't know offhand how many impacts.
    Level IV NIJ armor is rated to stop at least 1 hit of .30 AP at approximately 2800fps. There are multi-hit level III and IV plates out there, too.
    Information from Wikipedia here
    January 16, 2013 at 2:47 AM
    AM
    said...
    StukaPilot,
    If the Zetas come knocking, the hard plates in their body armor will stop anything a 308 can push out.
    However, hard points in body armor are inflexible, and pretty much any bullet from a 308 can punch through "soft" body armor.
    Make like a sniper and aim for the hips, give the Zetas a bad day. I know of no company that makes hard plates (either ceramic, polymer, or armor steel) specifically for the hip area. Doesn't mean it isn't out there though, but if I were being attacked by the Zetas, that is what I would do.
    January 16, 2013 at 4:13 AM
    Anonymous said...
    I would presume the Zetas (which in reality will be the second line confiscators) will come in with shields, so go for the feet. Our local cop show a well armed suburbatopia outfits each entrant in 3000 dollars worth of armor, so presume it is way beyond a PC with ceramics for each. A friend of mine suggested Molotovs, but I'm sure the 6 second rule trained entrants go by will negate that option. I suggest pray to Odin and Thor. RRS
    January 16, 2013 at 6:44 AM
    riverrider said...
    as to your article- thermite. as to the entry team-dotfifty, or multiple 308 hits will set them back on their ass where you can shoot his naked underbelly. THATS why we need 30 rd mags.
    January 16, 2013 at 9:25 AM
    Mt Top Patriot said...
    Dear AM,
    Barriers?
    You realize what just happened in NY?
    They just shut off the northeast corridor. You can not get in or out of New England with your arms without traveling through NY state.
    You see the set up here?
    Tactical and strategic choke point. With rolling VIPR teams on the roads they can ambush at will whomever they wish looking for persons, arms, and materiel.
    Something you write about often.
    NY is a kill zone. A funnel to channel enemies of the state into so they can be picked off piecemeal.
    To get those who aren't afraid.
    Along with it being an outright strategic act of war on our Liberty to defend from tyranny, a litany of acts of treachery, treason, and tyranny, this is in direct contravention of Article 10 of the US Constitution-Powers Prohibited States. Of course it is in direct violation of the 2nd, 4th, 9th, Amendments.
    The ruling class always has others do their dirty work. They are nothing but corrupt windbags without useful tool minions to commit the deeds required to impose their assumed power.
    That usually requires participation of armed forces in some manner when the serfs revolt.
    Something already in place.
    As these acts of tyranny escalate, a breaking point approaches. The blood is going to run. Lots of it. So when the dot mil gets called out by the elites to reinforce the enforcers because a bunch of deer hunters hand them their traitor arses and whittle down their numbers, what are you going to do?
    I'll tell you what I'm going to do AM.
    I'm going to fight like a cornered animal. I'm going to fight to win. I'm going to exact a comeuppance that will chill the blood of the elites.
    When you get called up to carry arms and enforce diktat on American soil, against sovereign Americans, what are you going to do AM?
    When it is marshal law, by name or not. What are you going to do AM?
    This goes far past that Oath I keep asking you about.
    January 16, 2013 at 9:55 AM
    PS,
    “A man must stand for something or else he shall fall for anything.”
    January 16, 2013 at 10:00 AM
    AM
    said...
    Mt Top Patriot,
    I've been thinking about the situation in New York. When I have thought enough I may even write about the situation.
    However, the Firearm Owner's Protection Act has a "safe passage" clause, even though New York has refused to honor it in the past.
  5. john316
    john316 Monkey+++
  6. john316
    john316 Monkey+++
  7. arleigh
    Seems to me , I have no military training, but prudence dictates not waiting till trouble meets the door .
    Meeting the enemy in the field is preferred ,is it not ?
    Knowing they are coming , and at which point is to your advantage is key .
    If you are a sitting duck , a drone will cancel your ticket.
    Drone technology will be vital in both offense and defense .
    Drones do not need to be air craft .
    If you are hoping to use a sling shot against an army, you've already lost.
    Technology will determine the winners and losers .
    Wired listening equipment is durable and having a trap set, enemy are likely to be using can give heads up ,
    useful for this detection and secondary communications for field teams .
  8. Merkun
    Merkun furious dreamer
    Wireless will be the death of a lot of people if it comes to projectile trading.
  9. Big Ron
    Big Ron Monkey+++
    Some of you kind of jumped off the subject. From doing some research I would say that two foot of sand or water is good. 3/8 of AR500 steel used for targets?pricey though.
  1. Dunerunner
  2. oldman11
  3. Ganado
  4. Asia-Off-Grid
  5. Asia-Off-Grid
  6. Asia-Off-Grid
  8. DKR
  9. arleigh
  10. Motomom34
  11. enloopious
  12. lonewolf88
  13. VisuTrac
  14. chelloveck
  15. chelloveck
  16. TailorMadeHell
  17. 007
  18. Yard Dart
  19. dragonfly
  20. dragonfly
