Anyone have one of these printers? I want to label some things in my network cabinet and only need 10 or so printed.
@melbo, I don't have the heat shrink labels but I do have several sheets of laser labels from amp. They are laser and inkjet compatible. Let me dig them up and get the item number so you can see if you can use them. I'll drop it in the mail this week if you can. *edit* May have spoken out of turn. Can't find the labels. Might have tossed them.
I have a pretty good label tape printer at the office. That's what I've used at this point but the label adhesive doesn't like the cat5/6 very much and they keep peeling off. Will give the straw trick a try. Thanks guys
I print my labels out on regular paper, cut them to size and use clear heat shrink tubing to seal them in place. Looks just like a printed label and cheaper to boot.
Was wrong, I think they are Panduit labels. Look like these if I can find them. They do NOT come off unless you really want them off. Identification Lables, Signs, Tags and Tapes
Use the smallest size that will slip over the connector and it will shrink down nice and tight. This picture is some coax in the distribution network my new house, I have yet to pull CAT-6. Its a little fuzzy, but you get the idea. I used fairly stiff paper otherwise it would ave conformed to the coax perfectly.
BT made a comment about a 3GB limit on his ISP plan yesterday. Here's my stats since last switch restart 35 hours ago: It's interesting that I used to see (too high) packet errors until I upgraded all of my patch cables to Cat6 STP (properly grounded).
If you need some professional done labels.... shoot me an excel list of the cable numbers and I will get them made for you
You guys are serious! I like it. I might actually look at some clear shrink wrap, now. I've been using Post-It flags in assorted colors because I like color designation due to its rapid ID features, plus I use a foreign language, usually Hebrew. It's not pretty since I hand write the labels, but the less information I can give to the "enemy", the better.
It makes a difference. BTW there are also companies like Blue Jeans cable that test and certify their cables: Blue Jeans Cable -- Quality Cables at Reasonable Prices I used their coax cables to extend my houses network to my cable modem. Really nice stuff - quality cable, quality connectors, quality assembly.
Looks great with individual cable test reports. I tested all of mine with a Klein tester and did find one that failed although I'm not sure if this tests noise and shielding or just proper pinning. Might look into Blue Jeans next time I'm re-working my system.
We routinely run into IT guys complaining that their Cat6 cable plant is not working right. In the end 99% of the time, they opted to buy their own patch cords, due to our prices on our proposals.... and ended up buying Chinese knock off patch cords with barely enough copper to pass Cat3 standards, let alone Cat6!! These Chinese patch cords have messed up many a network, that we get to fix at a premium!!!
Might need to send you an order for some US made and certified patch cables YD. These are working so far but are probably Chinese.
I was seeing 10% packet loss to one of my devices and couldn't figure out the problem. Swapped the cord with a fresh 6a STP and the issues disappeared. I so wish I could route new cables in my walls. Next house
