Radical Firearms 16" 7.62x39mm Barreled Upper with Fail Zero 7.62x39mm Bolt Carrier Group SKU: KIT-RF762BUR-FZ762BCG Manufactured by Radical Firearms Shopping $279.99 $459.98 In Stock NOTE: Limit 1 per household. Quantities exceeding 1 will not allow checkout. "We ship fast!" Order by 5PM EST M-F or 12PM EST Saturday and your order ships same day. FFL items may take longer to process. Details Radical Firearms Barreled Upper Receiver: The Radical Firearms 16” 7.62x39mm HBAR Barreled Upper Receiver is a law enforcement grade, drop-in solution for your next AR build. Crafted with quality materials and covered by Radical’s lifetime warranty, this MIL-SPEC upper receiver provides an outstanding solution for any budget. Arrives at your door with the hard work done. Finish the build with your favorite lower receiver, charging handle, bolt carrier group, and sights then head for the range! Includes the Radical Firearms First-Gen Thin Rail System, an ultralight and slim free float handguard for the AR-15. Features large cooling holes, multiple sling attachment locations, and a suppressor friendly internal diameter. Reversed KeyMod slots allow for superior mounting strength compared to traditional KeyMod cuts. Features: 16" 41V50 chrome moly vanadium steel HBAR barrel Chambered in 7.62x39mm with 1:10 twist rate 5/8x24 A2 flash hider 12" free float Radical Firearms FTR rail Made in the U.S.A. in Stafford, Texas! Fail Zero EXO Coated 7.62x39 Bolt Carrier Group This 7.62x39 Bolt Carrier Group (BCG) comes fully assembled and ready to drop into most mil-spec upper receivers chambered in 7.62x39. All critical parts are coated with EXO Nickel Boron technology that provides permanent dry lubricity, extreme durability and increases both wear and corrosion resistance. EXO Nickel Boron makes for easy cleanup even with the corrosive 7.62x39 ammo and will improve the performance of your rifle. The bolt keeps the Mil-Spec length for a more reliable bolt. The Extractor hardware includes a heavy spring, silicone insert, and o-ring to give better extraction tension. Included is a Black Rifle Arms Enhanced Firing Pin that has a longer length as well as other dimensional changes beyond overall length for better performance without over penetration. Due to the Mil-Spec bolt length and enhanced firing pin, you can shoot most Russian ammo including Tula. See More
