Battery tech for a battery bank
Discussion in 'Off Grid Living' started by Maxflax, Nov 16, 2014.
  1. Maxflax
    Maxflax Lightning in a bottle
    What's the latest and truly greatest? Longevity vs cost? [pop]
  2. BTPost
    Had to beat, Lead Acid for Power Density vs Cost.....
    Maxflax and sec_monkey like this.
  3. Maxflax
    Deep cycling lead acid ? I've watched overall battery tech soar, that do surprises me [melbo] Nice thing is if you can obtain them dry they would store forever on the shelf (spares for the Z Apoc)
    Any good online sources?
  4. BTPost
    InterState Battery in Everett, WA is where I get mine.... Deep Cycle is nothing more that a Battery with Heavy Plates, as opposed to a Starting Battery, that has Lighter Plates, but more sintered Surface Area, for more Cranking Amps....
  5. Maxflax
    Thanks again, friend, I'll check Interstate out
  6. Dunerunner
    Good information on the Exide web page...
    Flooded
    Maxflax likes this.
  7. Maxflax
    Thanks, Dune, those are interesting and informative options [chopper]
  8. kg4jxt
    kg4jxt Monkey
    Lithium Iron Phosphate batteries are up-and-coming. They are still more expensive than Lead, but the charging characteristics are much better - they take full current until they are full so they store power more rapidly - and they are good for more cycles - and they can be fully discharged so you can use a smaller bank. They are becoming popular on high-end yachts. Prices will come down. I expect my next bank will not be lead (in a few years).
    BTPost likes this.
  9. Maxflax
    Going off grid ASAP when the castle is finished, so maybe 2 years max. I'm assuming the two types are not interchangeable in the same system?
  10. kg4jxt
    kg4jxt Monkey
    I don't think the two are interchangeable within the battery bank - cell voltages are different, but there are LiFeP batteries with similar nominal voltage to 12V lead batteries, so one could change the bank at a later date and retain the same equipment for charging and inverting and so forth.
    Dunerunner and BTPost like this.
  11. Dunerunner
    Spot on Kilo/Golf four, Juliet/X-ray/Tango...
    Not only are the cell voltages different, the rates at which the cells give up energy and recharge are completely different. Having mixed batteries in an array is asking for problems. Like having automotive cranking batteries in the array with Deep Cycle RV batteries, there are always issues. Even like batteries with different internal resistances causes problems. Old batteries of the exact same manufacture, type, voltage, and rated ampere hour rating but with different discharge rates (the length of time they will provide optimum output to a fixed load during discharge) can cause premature array failure.
    You can't just set it and forget it...
    Decent web page here.. http://www.wholesalesolar.com/Information-SolarFolder/battery.maintenance.html
    And a good PDF here .. http://www.poweringhealth.org/Pubs/Guyana_Solar_PV_Systems_Maintenance_Guide.pdf
    kg4jxt likes this.
